Hi all,
I m having some issues with the render, I dont really understand why.
It looks random to. My render stops all the time after few frames, but when I restart is from that very same frame it render fine, goes forward, and stops at another frame.
Here is the link for the scene file, and I attached the log file as well.
http://we.tl/jTbsimMENQ
Thank you!
render erro
- octane 2.23.2 150913 101604.log
- (23.55 KiB) Downloaded 143 times
What's your gpu? How much free vram do you have while rendering?
i'll let it rendered to see what happens.
I am having the same problem. The display driver stops and recovers , so I assume that could cause some problems. I use the 255.82 nvidia driver and I am having random display erro messages when I use octane.
Do you know about any nvidia driver related issues?
So should be a driver/gpu related issue. I hardly remember some posts about issues on some driver versions. You may try older whql driver.misi wrote:I am having the same problem. The display driver stops and recovers , so I assume that could cause some problems. I use the 255.82 nvidia driver and I am having random display erro messages when I use octane.
It show Cuda error as you see. It's not directly related with plugin and not transparent to understand the problems. Possibilities: out of vram, reaching the triangle limites, some errors on gpus.misi wrote:I installed the 344.75 version and test it.
Have you got anything useful from the log file?
First two not possible in your scene and with current gpus. So my idea is that about a problem on gpus.
