3DS Max Plugin Not working correctly
A forum for discussion, development and support, including subforums for discussion for various plugins for octane render and 3d the relevant animation packages
shermanjas
I need help bad. Working on a big project and Octane is not working correctly in 3DS max. I have down loaded version 2.04 and installed. Octane works the first time 3DS max is opened but once 3DS max is closed and re opened nothing about octane works. It shows up but will not render. If I reinstall Octane it will again work on the first open of the application but stops working again after close. The standalone version seems to be fine.
I am running a dual xeon with 128 Ram and 4 Titan'xs and
my slave is a i7 5960x 64gb RAM and two Titan X'
I NEED HELP BAD AND AS FAST AS CAN BE I HAVE A DEADLINE I CAN NOT MISS>
Sincerely,
Jason Sherman
I don't have an answer, however version 2.04 is incredibly old - you probably want to update to the latest version. And for anyone to help you, they will need to know which Nvidia driver version you have installed, and which version of 3ds max you are running.
shermanjas
I have installed the latest 3DS max Octane version 2.23.2 and still have the issue. Open a scene directly after installation and it works until you close octane. Once 3DS max is closed and then re opened Octane does not work. It looks like it should work but the render viewport comes up blank. I am using 3DS max 2014 Version 17.0 SP1
I am currently running the latest Nvidia drivers version 355.82
I will pay for help at this point.
PLEASE I NEED HELP
Sincerely,
Jason Sherman
Jason - may I suggested posting your problem in the viewforum.php?f=27 forum, which is specific to 3ds max. If urgent, you could also email via https://home.otoy.com/get-support/. Not all support staff work through the weekend, so you may need to wait for Monday for a response.
oguzbir
I use max 4 octane on a daily basis.
So since I and any other users do not report the issue.
Your problem seems to be occurring in your current setup only.
I sadly have no suggestions than re installing max, Not sure if it work though.
License wise
if you own standalone along with octane for max. test if it works with standalone.
If you only have max plugin. make sure your license might need to have both standalone and max activated on same machine.
Maybe re-install a lower version of max ( say if you do your main work on max 2015, re-install max2014 or 2016 )
That way you wont loose any of the settings or scripts in your main max version
See if you have the same problem with those.
İf they have the same problem after you install. Than the problem might be with the nvidia drivers.
Uninstall all of the nvidia drivers.
Restart with no nvidia drivers installed. And then install a previous version of the nvidia driver. (the one before latest driver)
Lastly One of your gpu's might be failing. remove all but one cards and test again.
You can just solve it by eliminating suspects one by one
Edit: Then pay me :) Just kidding.
Good luck
My Portfolio
NVidia drivers have some issue with TitanX that shows up when 3ds Max draws its native viewports output. CUDA becomes not available during Max is using the accelerated viewports redraw...
So far we've seen this issue when DirectX mode was used in 3ds Max. So you can try to switch to OpenGL mode in Max, perhaps it helps...
shermanjas
Thanks for all of your help. However I am still having issues. I re installed 3DS Max and Octane for 3DS Max. with all of the latest versions. Once again the first time I use Octane in 3DS Max it works. If I close Max and reopen it. Octane no longer works. It does not recognize my GPU's at all. I have switched the Max display driver to OpenGL in Max and it still does not work.
My deadline is fast approaching and I will not be able to meet it if this is not resolved today..
Sincerely,
Jason Sherman
Return to “Plugin Discussion/Support”
