Easy Duplication of Complex Materials?
jayroth
Hello,
I have a mix material that I would like to duplicate, but whenever I do, only the mix node itself is duplicated; the contributing materials are not duplicated. Is there a way to "package up" a complete material for easy re-use or to be able to adjust separately? I have a bunch of jelly beans in a jar, and the LiveDB Banana material is a great starting point, but I don't want all of my beans to be yellow :)
I have tried dragging the banana material to my local DB, but Cinema hangs when I do that (100% repeatable).
Thanks!
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
Yambo
Use the user section on the livedb :) works great for mix materials.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
hi,
there is a known problem in saving materials to the LocalDB and the latest SDK, is not plugin related, there should be an update asap ;)
sdanaher
Its a cinema issue, same thing happens with vray. You can just create a null object and put all the used material tags on that. Then you can copy/paste, or save as a user object and all the mats propagate.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
