X-Particles and Octane
AlvaroLetelier
Hi amazing creative people.
Before purchase X-particles I want to know about the integration of the plug-in with Octane render. I know that you can convert any particles system into geometry, doing so any render can handle it. But, even so, I'm curious about it.
Cheers !
Atm, best to use render instances option in Generator objects of XP. There is a particle engine option but still experimental. I'm working on for 3.0 to add more and better options. Ex. direct access to particles, volumetrics, etc. We will do it better with OSL system.
miohn
sorry for asking in this topic!
Because you said, that youre working on 3.0:
3.0 will have no more triangles-limit, is this right?
Have to fight a lot with polycounts at current project.
Any rough estimation about release?
thanks
Mike
Yes it's on road map. But I don't have any info about when will be added.
Yambo
aoktar wrote:Atm, best to use render instances option in Generator objects of XP. There is a particle engine option but still experimental. I'm working on for 3.0 to add more and better options. Ex. direct access to particles, volumetrics, etc. We will do it better with OSL system.
This will be super helpfull.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
bleepurchin
Hi there,
I'm using X particles with Octane. I have a Trail object with sweep nurbs. It's not rendering in the viewer. Is it not possible to render X particles Generators?
Thanks.
Software: Cinema 4D r16, Octane v2.24.2 R1
Hardware: Intel Core i7-5930K CPU 3.50GHz, RAM 32 GB, 3x GeForce GTX 980
SephirothNP
Hi Bleepurchin-
Should be no problem to render trail object with a Sweep nurbs, I do it regularly. Is this still not working for you after a restart of Octane and/or C4D?
Falcon Mach V
i-4390k/32GB
GTX 780Ti
bleepurchin
SephirothNP wrote:Hi Bleepurchin-
Hey there,
I baked the sweep nurbs trail using Nitrobake in the end. The render of X-Particles seemed to be quite unstable and the first frame would usually not contain it... I'm wondering if it had anything to do with the scene size though...
