Rhino - z-depth min option missing
Micha3D
how can be defined the black point of the z-depth? Without this option a wide greyscale range is wasted.
(And why are in z-depth kernel mode options shown like AO distance, ... ?)
Ciao,
Micha
Win7 64 | Dual Xeon E5-2687W | GTX 1080ti 11GB + GTX 780 6GB | Rhino3D
I'm sorry, I don't understand this question. In the Render Passes, there is a Z-Depth max value you can adjust. The min value is 0.
The InfoChannel kernel has both an AO Max distance pin and a Z-Depth Max pin. They control the distances used in the "Type" pin for Ambient Occlusion and Z-Depth respectively.
Micha3D
No z-depth min option here - see screenshots.
I think only needed options should be shown. It's confusing to see dozen of options that are not needed in current mode. At other software packages unusable options are hidden or greyed out. The Octane UI looks like made from engineers for engineers, who are testing a new great thing with hundred of knobs, and because it's quick build, there a lot of knobs without function in current mode. I think, for 3D artists the UI needs to be redone. I can live with the current UI, it's only a suggestion to make Octane more userfriendly.
(The automatic expanding option tree is confusing.)
Yes, that's exactly what I said.
Micha3D
Oh, I understand, that's bad. For example Postwork DOF or other effects it's good to control max and min. Should be a standard options, often used at Vray.
