OctaneRender for Maya 2.23.2 - Plugin not loading
Digitaline
Hello everybody,
One of my PCs cannot load the octane plugin (OctaneRender for Maya 2.23.2 - 7.4) on Maya 2015.
After the installation, when launched from the maya's plug-in manager, I only get an error message :
// generating Maya nodes...
// AbcExport v1.0 using Alembic 1.5.0 (built Jul 25 2013 11:21:20)
// Error: file: C:/Program Files/Autodesk/Maya2015/scripts/startup/autoLoadPlugin.mel line 46: Unable to dynamically load : C:/Program Files/Autodesk/Maya2015/bin/plug-ins/OctanePlugin.mll
La procédure spécifiée est introuvable. (The specified procedure is not found.)
// Error: file: C:/Program Files/Autodesk/Maya2015/scripts/startup/autoLoadPlugin.mel line 46: La procédure spécifiée est introuvable.(The specified procedure is not found.)
(OctanePlugin) //
// AbcImport v1.0 using Alembic 1.5.0 (built Jul 25 2013 11:21:20)
updateRendererUI;
updateRendererUI;
// Error: line 1: Unable to dynamically load : C:/Program Files/Autodesk/Maya2015/bin/plug-ins/OctanePlugin.mll
From what I understand, it cannot found the file in C:/program files.
At first I thought "well, of course", since all of my Maya's stuffs are saved on c:/Program and, not c:/ Program files
I deleted all remains of octane, then tried to reinstall it in the right folder, but couldn't.
The installation file "OctaneRender for Maya 2.23.2 - 7.4.exe" do not allows me to have a word in where I want it saved, it goes from accepting the license to the install button, without asking where it will be installed.
So then I tried to make it work by copying all my maya files from Program to program Files, so it would eventually find the right files in the path it wants to take when loading the plug-in.
But it didn't change a thing.
Still not loading, with the same error message "couldn't find the file"
I have no idea of what to do next.
I'm working on a PC running on Windows 7 professional, and with already installed multiple versions of maya (I don't know if it matters or not): Maya 2010, 2012, 2014 and 2015.
thanks a lot if you can be of any help.
The installer does not need to be pointed to Maia install directory manually, it is retrieved automatically from the Win registry (where Maya puts it during installation). So, perhaps you've just moved Maya files manually after Maya was installed?..
And why are you installing the 7.4 version when 7.8 is available?..
Return to “Autodesk Maya”
