Feature Request: Assign Imager by Object or Material
jayroth
I don't know if the Octane architecture would allow this, but it would be very effective to assign imagers by objects or materials. For much of my work, DL can work fine, but when I need path tracing, it is rarely for the whole screen. Sometimes it's often just a small portion. To be able to make that particular object as path traced while the rest of the shot was DL would really increase render throughput.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
hi,
I think you intend "assign kernel by object or material", right?
Why don't you use the render region option or the render layer pass with the desired kernel ?
jayroth
Thanks, I'll look into that. I'm fairly new to Octane, so I'm still learning about what it can do (as well as best practices). Do you have a link, perhaps?
Propably this is most fantastic request for Octane. I think that's hardest thing on universe, to run different kernels for different objects/materials. Imagine that still couldn't figured per objects ray switchs. Running two or more kernels at same time propably would spend lot of resources and computation power. Will make everythings is more complicated in the Engine.
PT can be fast as DL if you set it properly. See tutorials section in this forum. There is some videos to explain parameters and optimisations. Also see manual but tutorials are better.
And take a look for incoming version. There is not any change like this but will be some powerful additions.
http://home.otoy.com/render/octane-rend ... -renderer/
jayroth
Octane 3 looks great! When can I get it? :D
TonyBoy
jayroth wrote:Octane 3 looks great! When can I get it? :D
From promo: "OTOY will be inviting select users to participate in the alpha release of OctaneRender 3 this summer, with a full release slated for the second half of this year."
jayroth
That presentation that Aoktar liked to says free and open alpha starting in June 2015, so I don't think any word that has so far been given will likely be the case in the end...
