Damaged Photoshop Data
sdanaher
Keep getting this Photoshop error when opening PSD Tiffs saved from Octane renders in Cinema.
Layered file has Channels except for the main RGB pass.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
Your other message make me thinks that your big renders much stresses your gpu. This may cause a file corruption. I'm not sure anyway, consider that's a just estimation atm.
sdanaher
Never had a problem saving image files before. Actually, not had a saving file problem with Octane before either. Done a couple of print jobs (not complex geometry) with it to test if I could move it to more complex projects.
The render is finished, so why the problem saving the file? It wasn't ever that big, just a magazine cover.
Codes of plugin can't corrupt a file. It's using C4D's save functions. There should be a different problem as i said that or so. Maybe a crash while saving. Please continue to test it and let me if you find anythings which can give me a opinion.
sdanaher
Yes, it doesn't make sense to me that its an octane plugin issue either.
Quick question is R17 ok to use or should I stick to 16.050?
sdanaher wrote:Yes, it doesn't make sense to me that its an octane plugin issue either.
I couldn't yet adopt the codes to R17. But plugin's R16 version is working on R17.
