Keep getting this Photoshop error when opening PSD Tiffs saved from Octane renders in Cinema.
Layered file has Channels except for the main RGB pass.
Damaged Photoshop Data
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
Your other message make me thinks that your big renders much stresses your gpu. This may cause a file corruption. I'm not sure anyway, consider that's a just estimation atm.
Never had a problem saving image files before. Actually, not had a saving file problem with Octane before either. Done a couple of print jobs (not complex geometry) with it to test if I could move it to more complex projects.
The render is finished, so why the problem saving the file? It wasn't ever that big, just a magazine cover.
Codes of plugin can't corrupt a file. It's using C4D's save functions. There should be a different problem as i said that or so. Maybe a crash while saving. Please continue to test it and let me if you find anythings which can give me a opinion.
Yes, it doesn't make sense to me that its an octane plugin issue either.
Quick question is R17 ok to use or should I stick to 16.050?
I couldn't yet adopt the codes to R17. But plugin's R16 version is working on R17.sdanaher wrote:Yes, it doesn't make sense to me that its an octane plugin issue either.
