Crash
Jolbertoquini
HI Guys,
Just a quick question I did some research on the forum but I didn't find anything about it, Is a issue have with Octane standalone, basically if in may machine I render images smaller then fullHD is work perfect if I render higher then that my computer switch off, Black screen and restart. :o This happening always with big renders. I check error is link the nvidia card problem says windows, so I update driver trying everything and still the problem uninstall and install no changes other machines work but I toke the same type of machine and this happening to in the workstation.
is a Lenovo Thinkstation D20 with Windows 7 64-bit Processor Intel xeon X5650 @ 2.67GHz with memory ram 16GB, I have one GTX 780ti and a Quadro 2000.
Any idea or advise???? :D
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
augdalmo
Hi Jolbertoquini,
I have encountered the same problem when I render, but at very high resolution, over 10000 pixles, it's not clear if the problem was due to the grafic card or Octane standalone, I have a PC configured as your, WIN 8.1 60 bit 1 xeon X5460 @ 3,16 GHz, 16 GB ram, one GTX 750 Titan Black 6GB and one Quadro K2000.
May be a problem with the power supply, I have a 1100 watts ps. I think the needs of watts by GTX exceed (on that situation) the max watts of power line for graphic card. I use only GTX for render.
Jolbertoquini
augdalmo wrote:Hi Jolbertoquini,
Yes, I tried to just with one Card the GTX still crash but you right may be power supply... I need test with a big one. Thanks to share your experience to really interesting
hi.
a couple of questions:
are you using the quadro only for display and the 780 only for Octane?
are you monitoring the VRAM usage?
Jolbertoquini
bepeg4d wrote:hi.
yes, and nothing change look normal in others computers. :|
Another one ;)
have you installed octane or just unzipped?
The installer should change some windows parameter for avoiding the timeout that is very important when working with displacement ;)
Jolbertoquini
bepeg4d wrote:Another one ;)
Yes I use the installer :D what ever version I use in just in the computer other with the same install is work fine.
Jolbertoquini
bepeg4d wrote:hi,
here you can find some more info about the timeout and how to manually change it:
http://render.otoy.com/forum/viewtopic. ... 80#p221480
Is not this issue, actually the computer switch complete off with render big then 2k if I render small sizes render fine.
Best
JO
in this case it seems that the PSU doesn't works as expected, have you tried with a bigger one or with an external one only for the GTX?
