disconnetced nodes
JNDesign
Hi Paul
Have been working for a few days in R14 octane 2.16.0.25 and just now I have lost some of my material.
Octane is saying "error loading OCS/ORBX. Either zer or multiple disconnected nodes were found."
20 mins ago all was well.
ANy ideas
Hi - I think I have found the issue. Can you pls tell me if this release resolves the problem?
http://render.otoy.com/customerdownload ... _Win64.exe
JNDesign
thanks for a speedy responce Paul
Will try it now and report back
JNDesign
bummer
the install has deactivated me from server
now trying to reactivate.......
JNDesign
Hi Paul
It now tells me what maetrial node has been disconnected but doesnt fix the problem
Is the material name given present in your defaults folder (ie. C:\Users\[username]\AppData\Local\OctaneRender for Revit\Defaults)? If so - can you pls send the ORBX file to me?
JNDesign
Morning Paul
Here it is.
cheers
BRISBANE BAR - TIMBER PERGOLA HORIZONTAL.ocs
(160 Bytes) Downloaded 509 times
Thanks - that material is blank/empty. I'm not quite sure how an empty material could be saved by the plugin. Do you recall how that default was saved? (before rendering, after rendering, is it a proxy material default?).
The easy solution is to delete that file and everything should be fine again.
Return to “Autodesk Revit”
