"An All Nighter" - By: Chipstarrr
OTOY [Bot]
An All Nighter
Submitted By: Chipstarrr
If the viewer above does not display correctly for your device, you can load the viewer directly.
Just testing my submission. 24 hours baked so far!!
Chipstarrr
Does anyone have any clue why the glow areas have rendered out differently on each section? Looks like I'm going to have to scrap this render :-(
Chipstarrr
Seems the glow setting in the post processing bleeds over the edges of the cubes!! Is this an error or my screw up?
ramone163
Here are 10 useful guidelines for rendering in VR using Octane:
1) turn off post processing.
Here you can find more info about it:
http://render.otoy.com/forum/viewtopic.php?f=16&t=46092
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
Chipstarrr
cheers for the link!
do you reckon its cheating to save 2 versions of the render, one with PP and one without. Then open them in photshop and just use the version without the PP to re-build the area wher the glow has blead over?!?
ristoraven
Chipstarrr wrote:cheers for the link!
I'd file that under "excellent solution" section in my book.
Chipstarrr
I'm with you on that! :-) seems to be my only option to keep the nice glow!!
ristoraven
Go for it. Great idea btw.
Chipstarrr
ristoraven wrote:Go for it. Great idea btw.
Thanks, its a real killer on the render times. Doubt I will be able to do a stereo version which is a shame!
Return to “OTOY & Oculus: Render the Metaverse Contest WIP”
