Environment Scale
heavypoly
Does anyone know how to change the size of an hdri?
LFedit
I think the only way to do this is to apply the map to a sphere with spherical projection and put it around your scene. I think the environment itself is infinite..
Not quite sure what you mean by "change the size", but if you mean scaling the environment map, this is not currently possible in the plugin, but is something I could add if needed.
heavypoly
face_off wrote:Not quite sure what you mean by "change the size", but if you mean scaling the environment map, this is not currently possible in the plugin, but is something I could add if needed.
Yes that's it. I ended up using LFedit's suggestion which works for now.
Return to “Foundry Modo”
