Environment Scale
Not quite sure what you mean by "change the size", but if you mean scaling the environment map, this is not currently possible in the plugin, but is something I could add if needed.
Yes that's it. I ended up using LFedit's suggestion which works for now.face_off wrote:Not quite sure what you mean by "change the size", but if you mean scaling the environment map, this is not currently possible in the plugin, but is something I could add if needed.
