Emission - Fresnel effect?
bleepurchin
Hi there,
I've been playing with the emission option in the medium tab of the specular material and cant get the emission to be only around the edges of the object I'm applying it to. When using native C4D materials it would simply be case of plugging the Fresnel shader into the relevant slot. However, I've tried this and I've tried using the Falloff shader in Octane and nothing appears to have any effect.
What's the answer here please?
Luke.
Software: Cinema 4D r16, Octane v2.24.2 R1
Hardware: Intel Core i7-5930K CPU 3.50GHz, RAM 32 GB, 3x GeForce GTX 980
uncia
Hope it helps you ;)
Volume_emission_Edge_Inner_and_so_on.zip
(99.22 KiB) Downloaded 909 times
Volume_emission_Edge_Inner_and_so_on.mov
(19.49 MiB) Downloaded 9337 times
dotcommer
I'd assume you could use a dirt shader to isolate the emission to just the edges. I'm sure thats what Uncia did in his example scene above (don't have octane at this comp so can't check for myself).
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
bleepurchin
Hey thanks for taking a look at it.
What you've got is certainly a useful technique but it isn't a Fresnel effect.
A Fresnel works by constantly adjusting to where the camera points. So if you have a sphere, the sphere always has what looks like a ring of light around it wherever you look it it.
If I put your material on a sphere I get a load of polygon squares that make up the sphere... cos dirt doesn't work in the same way as a fresnel.
The sphere on the right is what I get with yr material. The sphere on the right is what I'm after (c4d native render shown).
Anyone got the answer? I'm kind of surprised this hasn't been addressed before....
uncia
Omg man . Take it :D
Volume_frenel_emission.zip
(117.13 KiB) Downloaded 972 times
Or you can use gradient + fresnel. Gradient can change the falloff curve.
bleepurchin
Yesss! There we are!
Cheers guys! :D
bleepurchin
Ok seems I have a bug...
I have no Emission Efficiency option in the Texture Emission shader....
Anyone know what I do here please?
Screen Shot 2015-06-17 at 12.37.01.png (35.73 KiB) Viewed 10488 times
Luke.
bleepurchin wrote:Ok seems I have a bug...
Luke.
hi, it has not this pin. so that's not a bug. But i missed to change name to "texture" in nodes.
bleepurchin
Oh I see.
Thanks!
