Question: please take a look at this image - https://www.clinique.com.au/media/expor ... t_5_30.png
What would be the best way in octane (with lightwave) to get something similar? Just a little soft reflection and a little soft shadow. Rest of floor and background 100% white.
Any tips?
Another question: I was trying to use alpha channels, inside lightwave you could use in the surface panel/ advanced/ alpha channel/ constant value 0 or 255 to in or exclude objects in the alpha channel. How can I do something similar inside Octane?
Hope someone can help me with these 2 questions.
Thank you so much!!
Freddy
Product on white floor white background - alpha
Sorry, Octane doesn't support custom values for the alpha channel in the surfaces. You should use render layers if you need to break your scene in layers to make something with them in post.
http://render.otoy.com/manuals/Lightwave3D/?page_id=717
Hello,
to get this kind of image, you can put a white emitter on the back of your scene,
a white glossy ground (tweak with the refraction index to balance between the brightness of the back,
the reflections of the objects and the white of your ground)
Then put 2 lights on the right and left side of your scene to light your object, all is a question of
balance between these 3 main sources of light :)
Oliv
Oliv
Hi Juanjo,
I don't have that layers option in Octanerender for Lightwave 2.16, I even don't see it in the octane_menu.cfg. Am I missing something?
Freddy
Freddy
Yes, you need to update your plugin to the 2.2 version, the last release is 2.23.2.1sjonsjine wrote:Hi Juanjo,
Freddy
http://render.otoy.com/forum/viewtopic.php?f=36&t=46205
This build will be released as production build next week.
