su8
andrear
hi tig,
it do not work in my 8pro version.
it has not effect at all clicking over any of the links or buttons.
hope you can fix it.
andrea
MSi GE75 Raider 8SF - W10PRO - RTX 2070 8GB mobile
TIG
The Sketchup Octane Exporter works just fine in SUp v8... IF it's properly installed.
I suggest you remove the 'octane loader' .rb file and the whole Octane sub-folder in Plugins.
Check for other rogue files in the wrong folders and remove them too - look through the files in the main zip-file to see what files/sub-folders should be where...
Then make a completely fresh install following the instructions...
Extracting the files/sub-folders with files etc exactly as they appear in the zipped file.
If the problem persists please open the Ruby Console, try to run the Octane Exporter and see any error messages, post error messages here as these will help track down your problem..... :?
TIG
andrear
thank's tig,
I'll try it.
andrea
Return to “SketchUp”
