Hi!
I'm in trouble with 32bit layered EXRs, they look different when composed, and its a huge space consuming. Could we have a dialog or any script to save 16bit instead of 32?
tnx!
16bit Multi-layer EXR, is it possible?
- marcus1070
- Contact:
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
I will add this to the next release.I'm in trouble with 32bit layered EXRs, they look different when composed, and its a huge space consuming. Could we have a dialog or any script to save 16bit instead of 32?
- marcus1070
- Contact:
Thank you very much Paul!face_off wrote:I will add this to the next release.I'm in trouble with 32bit layered EXRs, they look different when composed, and its a huge space consuming. Could we have a dialog or any script to save 16bit instead of 32?
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
- marcus1070
- Contact:
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
This will be awesome. I HATE converting from 32 bit to 16. I guess I just don't know enough about linear workflow.
I found out if I bring it into after effects though and edit at 32 bit linear. Then you can export as a 16 bit tiff from AE and bring into PS. Wish photoshop had better tools for linear 32 bit exrs...
- studio3lhd
Have you tried...LFedit wrote:This will be awesome. I HATE converting from 32 bit to 16. I guess I just don't know enough about linear workflow.
http://www.randomcontrol.com/arionfx-for-photoshop ?
Layered import of 32bit images works like a charm. The plugin itself is slow as hell, but the importer works gr8.. For only a hundred bucks..
Octane for Modo (v 2.22.2.68), Modo (801 sp4);
2 x TITAN Black,
I7, 32GB RAM.
2 x TITAN Black,
I7, 32GB RAM.
Yeah the problem I have though is getting it down to a 16 bit file without losing the color changes. The only way I found to get it to work is by opening it up in AE, then editting it. Then saving it out as a 16 bit tiff. Then bringing that into photoshop. It works great, but am looking for a better solution, Faster.
The current TEST version of the plugin allows saving to multi-layer 16bit EXR's.
