Free projector/spotlight prop!
ThetaGraphics
Hey all, I made a simple projector that is capable of projecting images or gobos (or if you simply need a directional spotlight) in Octane.
It works by placing a specular screen in front of a bright light source, but the principle is that the light source must be very tiny and very bright, or else you will only get a blurry image. I'm certain that what is really happening is that the resulting point light is emulating the focal point caused by a lens, thus resulting in a clear image.
The prop has my logo on it which can be used as a reference point in aligning the orientation of the projected image. Basically, the logo is on the side of the top of the image. The projector is not intended as an in-scene prop, but rather a source of illumination.
Here are some examples of the projector in action:
As well as a LQ video clip:. http://www.thetagraphics.com/octane/test/!proj1.swf
The gobo image of the rings and the poc file is included. All I ask is that I get credit, and I am interested in seeing what you all do with it. Enjoy! ;)
EDIT: Fixed the video link. Also forgot to mention that to change the projected image, simply replace the image in the Transmission node in the Gel material. If its too dim or too bright, just adjust the emission power of the lamp. Also, in the promos I imported the obj at 50% figure size, in case you're not getting similar results.
theta-spotlight-proj.rar
(838.72 KiB) Downloaded 721 times
OctaneRender - DAZ Plugin
Win 10 64-bit | Intel 17-5930K 3.5GHz| RTX 3090 and GTX 1080 | 64GB RAM
ch0pper
looks good thanks
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
Great work. Thank you for your contribution.
samhal
Excellent work on this...but I guess I'm stupid. All I get is a spotlight effect. I plugged in the image into the Transmission node on the Gel and it's completely dark. Lowering the Opacity gives the spotlight effect, but never do I get the effect you show.
Still playing with it.
Still, what you've created is GREAT!!! Thanks!
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
ThetaGraphics
Hmm, did you load the materials from the poc file?
If so, can I see the picture you are trying to use? And the gel and lamp settings as well?
samhal
ThetaGraphics wrote:Hmm, did you load the materials from the poc file?
Aha! No I did not load from the POC! Duh.
Ummm...how do you do that? Via Poser or plugin?
ThetaGraphics
RIght-click on 'theta-spotlight-proj [Mesh]' in the plugin and go to 'Import All Materials for this Figure/Prop' > 'Use imported Image Maps' and find and select 'theta-spotlight-proj.poc'. This should load everything correctly and will put an image called concentric3.jpg into the Gel's transmission node. Replace this with whatever you are using.
The lamp may be a bit dim, so feel free to increase the emission power to 4 or 5 thousand or so.
samhal
Works like a champ!! Thanks again!!! :D
ThetaGraphics
You're welcome. ;)
martincarlson
Could not use your file since I'm on Cinema4D - but I thought It was an awesome idea so I had to try it based on your explanation. Here's a test:
https://vimeo.com/129819738
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
Return to “Poser”
