OctaneRender® for 3ds max® v2.23.2 - 1.9 [OBSOLETE]
Don't switch the current critical projects to this major version, as you may need to re-tune the scene for them.
Changes since the 1.8 version
  • Added 3ds Max 2016 support.
  • Added stereo mode parameter to Octane camera.
  • Octane viewport now eats less resources if paused.
  • Minor fixes and improvements...
Changes of the 1.8 version
  • Fixed the Octane light On/Off - Visible/Invisible mess.
  • Implemented the gradient texture support for Octane DB. This fixed the crashes when importing the materials having gradient textures in them.
  • Added the missed "Smooth" parameter to gradient texture.
  • Materials imported from Octane DB now are named according to DB material name.
  • Added parallel processing to some parts of global meshes translation. Should be a little faster now...
Changes of the 1.7 version
  • New 2.23.2 engine.
  • New "Cube map" camera modes added: now you can render different faces of cube map separately.
  • Fixed the bug with saving the values of "alpha shadow" and "keep environment".
  • The OctaneProxy unit scale is now respected if inserted from the OctaneProxy-file saved from plugin version 1.7 or later.
Changes of the 1.6 version
  • Added stereo mode for panoramic camera.
  • Added "Lock camera" feature to Octane viewport.
  • Fixed Octane viewport background bug.
Changes of the 1.5 version
  • New 2.23.1 engine (see the standalone changelog).
  • Added the "Cube map" camera mode.
  • Fixed the Octane viewport crash bug (thanks to Pancir).
  • Fixed hair&fur bug (thanks to oguzbir).
  • Fixed Octane render settings dialog bug (double rollouts in some cases).
  • Added some lost textures to the Octane material DB.
  • The Octane viewport passes rendering now respects the settings of current pass if they are set in render elements.
  • 3ds Max versions prior to 2012 and 32-bit versions are no longer supported.
DOWNLOAD
OctaneRender for 3ds Max 2.23.2 - 1.9 (11.7MB autoinstaller file)
OctaneRender for 3ds Max 2.23.2 - 1.9 DEMO (10.2MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender® Team.
Goldisart
Hi JimStar ! Thank you for your work ! I have a question - function maps standart bitmap - will work in the near future ? or not
gabrielefx
thank you for the stereo camera.
RobSteady
Thanks for the update!
Jim, is this something you guys are discussing?
I think it's a very important topic...
http://render.otoy.com/forum/viewtopic. ... 85#p235257
DIO
Thanks for the update. Looking forwand to the performance boost in paused mode and the 2016 version. I´m going to check it out soon.
corei7-4930k 6 x 4,0 Ghz, 32GB RAM, 2x 980 Ti
Win7 64bit, 3dsmax 2014 / 2015
3dgeeks
Cam lock seems to be working now :)
mikinik
again does not work vertex motion blur (
.abc file, 2gb - https://www.dropbox.com/s/q4afkyq80f8d2 ... 1.abc?dl=0
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
mikinik
Octane is able to render the vertex MB only for meshes having constant topology.
This means the connectivity between faces, edges and vertices stays the same during the animation of this geometry. If this is the case - Octane may try to calculate motion blur from the motion of vertices between frames.
Dom74
Hello JimStar, with this release, on 3DSMAX 2016 (not tried with 2015), every time I start 3DSMAX, all GPU core frequency are going up, from 324 Mhz to about 1050 Mhz,
even with an empty scene and no octane viewport opened, so it is very power consuming when working on modeling or texturing, can you investigate about that, please ?
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
mikinik
JimStar wrote:mikinik
JimStar, why do not you can check out what I'm saying? I specifically for you put file. why should I prove it?(
to open a file in octane standalone need to resave it in Houdini. all other applications open it at once. only problem in octane. it is possible as that to fix it?
same scene in octane standalone. vertex motion blur works here.
