Changes since the 1.8 version
- Added 3ds Max 2016 support.
- Added stereo mode parameter to Octane camera.
- Octane viewport now eats less resources if paused.
- Fixed the Octane light On/Off - Visible/Invisible mess.
- Implemented the gradient texture support for Octane DB. This fixed the crashes when importing the materials having gradient textures in them.
- Added the missed "Smooth" parameter to gradient texture.
- Materials imported from Octane DB now are named according to DB material name.
- Added parallel processing to some parts of global meshes translation. Should be a little faster now...
- New 2.23.2 engine.
- New "Cube map" camera modes added: now you can render different faces of cube map separately.
- Fixed the bug with saving the values of "alpha shadow" and "keep environment".
- The OctaneProxy unit scale is now respected if inserted from the OctaneProxy-file saved from plugin version 1.7 or later.
- Added stereo mode for panoramic camera.
- Added "Lock camera" feature to Octane viewport.
- Fixed Octane viewport background bug.
- New 2.23.1 engine (see the standalone changelog).
- Added the "Cube map" camera mode.
- Fixed the Octane viewport crash bug (thanks to Pancir).
- Fixed hair&fur bug (thanks to oguzbir).
- Fixed Octane render settings dialog bug (double rollouts in some cases).
- Added some lost textures to the Octane material DB.
- The Octane viewport passes rendering now respects the settings of current pass if they are set in render elements.
- 3ds Max versions prior to 2012 and 32-bit versions are no longer supported.
DOWNLOAD
OctaneRender for 3ds Max 2.23.2 - 1.9 (11.7MB autoinstaller file)
OctaneRender for 3ds Max 2.23.2 - 1.9 DEMO (10.2MB autoinstaller file)
For network slave and daemon please download standalone installer here:
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender® Team.
