turtle in the water
plato13404256
hey,octers,my first pic,c&c are welcome!
and anybody can me how the water make well!
the water aroud the stone is not display right..
thank you
windows 7 64 bit| Geforce GTX260+ | i7 920 Quad 2.66GHz | ddr1600 2g*3 | 3ds max2010+octane
wow plato13404256, very good start :)
for the water, maybe it's a smoothing problem :roll:
have you try to uncheck the smooth value in the water material?
tomas_p
interesting...
regards
Win Vista 64 | Phenom II X4 905e |Gigabyte GTX690 and zotac Geforce GTX260 | 8GB
infernoVFX
Hi Plato,
Your water surface pattern is too small, it's not the proper scale. This way the stones and the turtles looks like giants. Try increasing the maxdepth samples, i believe this should remove unwanted shading.....
All the best,
Voja
Asus rampage III extreme, i7 950 OC 4GHz, Kingston 12GB DDR3, WD VelociRaptor 300gb, 2x WD Black 640gb, Asus ENGTX 580//
Gigabyte P67A UD7 B3, i7 2600K OC 5GHz! Mushkin Blackline 16GB DDR3, OCZ vertex3 SSD, WD black 1TB, MSI GTX 580 lightning OC 993MHz!
anomi
nice work, especially the shell, what shader did you use to achieve the shiny translucent feel?
ive seen several translucent renders around but they always lack specular.
ur water seems to be the only problem with this piece.
gigabyte mobo, core2quad, 8gb ram, x2 pny gtx 580,
hp pavilion hdx series(desktop replacement) 4gb ram, gt 8800
win7 x64bit, octane 2.3 v5
plato13404256
bepeg4d wrote:wow plato13404256, very good start :)
thank you!
but i will try!
plato13404256
tomas_p wrote:interesting...
regards
thanks!
plato13404256
infernoVFX wrote:Hi Plato,
All the best,
Voja
thank you!
i will do it.
plato13404256
anomi wrote:nice work, especially the shell, what shader did you use to achieve the shiny translucent feel?
yes,i think so.
may be i make the hdri and sun in the scene,will be ok.
thank you!
suhail_spa
its impressive...
very nice material on turtle..
mind if i ask you- how did you do it?
DELL Precision M4500 Laptop (win7 -64bit, Intel core i5 M520 2.4Ghz, 4Gb, Quadro FX880 1Gb, PCI express slot)
with GTX 460 -2GB (running on home-made GPU-expander)
