OctaneRender™ for Blender 2.23.1 - 8.2 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • New 2.23.1 engine.
  • Merged with Blender 2.74.
  • Added "Cube map" mode for panoramic camera.
  • Don't use the stereo mode anymore to disable stereo in the thin-lens camera, but the stereo output setting. This makes the stereo settings of the panoramic and thin-lens cameras consistent.
  • Added option "Pixel aspect ratio" to the thin-lens camera node, which allows you to render to a non-square pixel format (like NTSC or PAL).
  • Added option "Aperture aspect ratio" to the thin-lens camera node, which allows you to stretch/squash the DOF disc.
  • Added pin "Keep upright" to the panoramic camera node. If enabled, the up-vector is kept at (0, 1, 0).
  • Added "Over-under" stereo mode.
  • Added option "Pano blackout latitude" to the panoramic camera node, which defines the minimum latitude (in spherical camera coordinates) at which the rendering is "blacked out", when stereo rendering is enabled. This is to avoid eye strain, when people try to look up or down at the poles.
  • Minor fixes and improvements.
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v8.2 Linux (99.4MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
grimm
Excellent, thanks! :) Any chance for a git push?
Sorry, had no time left to finish it on Friday. Will push into GitHub it on Monday.
mac3d
Hi Jimstar, I have this error when launching blender..
blender: symbol lookup error: /usr/local/OctaneBlender/lib/libOpenImageIO.so.1.4: undefined symbol: _ZTIN3Imf7IStreamE
Please help you me.....
Thanks for this update
Ubuntu 14.10 64 bit
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
kaiwas
mac3d, +1
manjaro linux
./blender: /usr/lib/libcrypto.so.1.0.0: no version information available (required by /usr/local/OctaneBlender/lib/libOpenImageIO.so.1.4)
./blender: symbol lookup error: /usr/local/OctaneBlender/lib/libOpenImageIO.so.1.4: undefined symbol: _ZTIN3Imf7IStreamE
Check the OpenEXR library on your system is installed...
kaiwas
set Openexr 2.1.0
mac3d
OpenEXR library It is installed..
grimm
Hi JimStar,
When I try to render a panoramic and set the stereo to side-by-side it will only render 6 tiles (with cubemap selected). It should render 12 right?
grimm
Thanks for report.
This is a bug. Will release the quick-fix soon.
Return to “Blender”
