Start Frame for Image Sequence
fibernaut
Hi
i hope someone has a workaround for this. I want to apply an image sequence as a texture for texturing a lcd panel. The sequence is rendered out as a png sequence from AE. So far so good. The texture shows up and the playback works fine. The only thing that does not work is setting the start frame to determine on which frame in Layout the sequence will start. It always starts on frame zero. (it should start at e.g. frame 120) In VPR everything works like expected. From 0 to 120 it holds the first frame and from there on the sequence starts. But unfortunately not in octane.
Is there anything i can do to make this work?
Win 10 64 | 2x RTX 3080Ti 2x Xeon E5 2650v2 Supermicro X9DAi 128 GB
Win 10 64 | 1x RTX 4090 i9 9900K Gigabyte z390 128 GB
Win 10 64 | 2x RTX 3080Ti i7 2600 K 32 GB
juanjgon
Let me check this problem, but I think that there was an issue with the LW SDK that didn't support the frame range adjustments for external render engines.
juanjgon
Nope, this was an old issue. At least in LW 2015.2 all works fine with the "Start frame" parameter in any mode (drop frame, hold first frame and mirror loop).
What version of LW are you using?
fibernaut
11.6.3. But i also have 2015. I'll try it. Thanks!
Return to “Lightwave 3D”
