Hi
i hope someone has a workaround for this. I want to apply an image sequence as a texture for texturing a lcd panel. The sequence is rendered out as a png sequence from AE. So far so good. The texture shows up and the playback works fine. The only thing that does not work is setting the start frame to determine on which frame in Layout the sequence will start. It always starts on frame zero. (it should start at e.g. frame 120) In VPR everything works like expected. From 0 to 120 it holds the first frame and from there on the sequence starts. But unfortunately not in octane.
Is there anything i can do to make this work?
