Sodastream commercial
Erxxi
Hi!
I recently did a Sodastream commercial where I rendered it with octane 2.22 in Cinema 4d.
https://vimeo.com/124415386
pass: soda
ChrisVis
Hi Erxxi,
very well done! I like it. Not sure, which shot is real and which CG. :o
Not every shot is CG, right? Tell me, the 3 Glasses at 0:12 are real shots...otherwise you are a realflow expert.
May I ask some questions? :)
If the cooking water shot at 0:17 is CG, how did you achieve the sparkling bubbles effect?
And the big bubbles at the beginning and the middle: Did you use any plugins for that or just cloners and metaball? Xparticles? Realflow?
Only little thing that catched my attention, because it is a commercial:
It seems to be a bit noisy at 0:07. Did you use pathtracing and facing a hard deadline?
Glass and Water (deforming speculars) is hard to render for animation.
Thanx for sharing again!
This is top notch!
Cya,
ChrisVis
C4D R15 - C4DOctane 4.0 | Win7 64 | NVIDIA 417.22 | EVGA GTX 980 Ti SC | EVGA GTX 780 Ti SC |EVGA GTX 780 Ti SC
i7 4930K 6x4.3GHz OC | 64GB | ASUS P9X79-E WS
+ Netstor Turbobox 250A | 2x EVGA GTX 780 Ti SC + 2 x Palit GTX780 Ti 3GB | all watercooled
Erxxi
Hi Chris!
Thanks for the reply!
You're right, the three glasses is live action shot with a GH4 (but I wish i could say they're CGI :D)
the sparkling/carbonating shots in the packshot and 0:17 is made by using a texture sequence from the bubbles in the live action shot and playing around with opacity and refraction index in a specular material.
the closeup bubbles were made with a simple emitter and metaballs. no plugins.
the renders were a bit noisy due to tight deadline (direct lighting , but I also added some grain with film convert cause I wanted a 16mm look on the closeups.
ChrisVis
Hi Erxxi,
sounds like real production tasks mastered just fine. :)
The bubble close ups look very nice for directlighting. Very well done with C4D only.
Thanx for the info on the sparkling water shot. Mixing live action texture sequence is a very smart "workaround" for a otherwise hard to do shot like this.
Adding grain with filmconvert is great, but it sometimes gets messed up by online compression. I think thats the case here, at least thats my experience with much grain and h.264 compression.
Thanx again for being part of the community,
I`d like to see more. :)
Greetings,
ChrisVis
NVN
really really nice.
But at the last scene, the ice looks horrible..sry :-(
