Carrara crashing on loading Octane plugin
Carrara (Integrated Plugin developed by Sighman)
Neole
I posted this on Carrara forum first, then realized there's an Octane Carrara plugin forum so posting again here -
I bought octane and rendered my first video with it successfully (1:50 minutes long) and was very happy with Octane.
However now when I'm opening the same project, Carrara is crashing as soon as I open Octane. When I'm starting a new empty project and then loading Octane, again Carrara crashes everytime. I have restarted my PC and tried.
Config - Carrara 8.5, latest octane plugin (2.17 stable version), windows 7 64 bit, PC core i7 16 GB Ram, Nvidia graphics card.
Error message -
Problem signature:
Problem Event Name: APPCRASH
Application Name: Carrara.exe
Application Version: 8.5.0.243
Application Timestamp: 520e3965
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7600.17206
Fault Module Timestamp: 50e669a2
Exception Code: 80000003
Exception Offset: 00000000000335a2
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional Information 1: e7ce
Additional Information 2: e7ce883d5856ac81e79846fe730d206f
Additional Information 3: 7c75
Additional Information 4: 7c753af25cefc064fb70bef2dd044e24
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
EddyMI3D
Try to reinstall Octane for Carrara.
You will get the possibility to Modify, to Repair and to Remove.
Do a Repair. Maybe it helps.
Eddy
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
Neole
I did that just now and tried again. Carrara crashes whenever I open a new project and load Octane. Even if Octane is in pause mode it crashes. Strange thing is this never happened with the demo, nor with the animation project I just finished rendering with Octane. I will try again tomorrow, maybe I'll have better luck.
Sighman
If you are using 2.17 then please make sure you are using version 2.17.0068 and not 2.17.0066. If you continue to see a crash please PM me a scene file so I can reproduce the issue.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Neole
Thanks that worked! Downloaded the latest release and it's fine now. My version was 217066 while the latest is 217068. Though I had downloaded the latest version when I bought it a couple of days back, I had the demo installed from a month back so maybe that had something to do with it.
Return to “Carrara”
