Can´t save to folder??!
Re-Create
Hi!
I have a really annoying/frustrating problem that I hope that someone can help me with.
Since I´ve upgraded to v2.0 I have not been able to save to my regular folders.
I have a couple of dedicated "work" folders on my computer in which I have the current *.pln, drawings, pictures etc.
But since the update to 2.16 I cant save to these folders.
Archicad, PS, Adobe, the Stand-Alone Octane, etc can all save to them as usual. Only Octane AC plugin that seems to have an issue with just these folders.
The only difference between these dedicated "work" folders and saving to the c:/ My documents for example is that these folders are being synced to the cloud using SugarSync.
Besides that, everything is the same.
I´ve checked the write/read configurations. Re-installed Octane. Done it all.
Its installed in the same Archicad ROOT directory as before. Same OS. Same hard drive.
It worked superb before the update. Now it dosent work on either AC16 nor AC18.
Octane plugin don't say anything about the *.png not being saved, no pop-up, no "save failed" etc. It just don't manage to do it.
Anyone experienced the same?
Any suggestion on how to fix this?
It´s a minor issue, but nevertheless really frustrating to always create a new folder outside your "working" folders and then copy paste everything to where it should be.
Thank you/
Olle
Hi Ollo - this is possibly due to you folders you are trying to save to having special characters in them. Can you pls try with the latest build (2.22.2.42) which fixes this issue.
Re-Create
Hi Paul
And thank you. That did the trick! Works :)
And it had to do with special characters.
But now Ive found that the chosen folder to save in is "resetting" itself between saves.
For example: I open the "Save Render" window. Opens by default at C:/My documents. I click my way in the folder structure and choose to save in the render in C:/My documents/Work folder/Project1/Renders
Next time I click the "Save" button Im back at the default C:/My Documents
Found that its for the folders with special characters/ swedish å/ä/ö.
And that it "jumps" back to the folder previous to the one containing special characters.
For example; Save to C:/ My docu/ Work folder/ÅÄÖ/Project1/
"Jumps" back to C:/My doku/Work Folder/
Easy fix? :)
Thank you for your amazing work!
/ Olle
Hi - this is fixed in the latest release - 2.22.2.43.
