Activation error
- plazadelmar
I just purchased Octane standalone and C4d plugin. Standalone is activated but the plugin gives me a error message "can't connect to the server". Any suggestions?
OS X Yosemite | Geforce GT650M | i7 2.6 | 8GB
It may be a server connection problem or blocking by a firewall . What's your versions of plugin and standalone?
- plazadelmar
It says 2.x on my download page on both products. I installed the latest versions. I also deactivated firewall and the problem persists. Im on Latest OS X Yosemite and MacBook Pro.
What says in C4D script window? Can you open octane log window to see what says?
Also here we have a forum for development versions, help and more info:
C4D forum:
http://render.otoy.com/forum/viewforum.php?f=30
development releases:
http://render.otoy.com/forum/viewforum.php?f=85
C4D forum:
- plazadelmar
It says: The plugin ID 'xxx' in file 'Octane-for-C4D-2.16.2-Macosx' collides with the same ID in file 'Octane-for-C4D-2.16.2-Macosx'
hmm, what's the collision? Did not you deleted the unnecessary versions of plugin after unpack the package? It describes in readme.txt.plazadelmar wrote:It says: The plugin ID 'xxx' in file 'Octane-for-C4D-2.16.2-Macosx' collides with the same ID in file 'Octane-for-C4D-2.16.2-Macosx'
- plazadelmar
I did now and the only error message left is this one:
Octane Render for Cinema 4D 2.22.2
Octane Render SDK version: 2.22.2
/Users/xxx/Library/Preferences/MAXON/CINEMA 4D R16_9AF11231/prefsoct.dat
Initialization error!!!!
This is a error because of failed registeration of plugin. Are you giving correct userId(7500xxxxx) on plugin account section?
- plazadelmar
aoktar wrote:This is a error because of failed registeration of plugin. Are you giving correct userId(7500xxxxx) on plugin account section?
Yes, of course. Im using same user id and password as I was given in my account. Maybe something went wrong on your side and you should resend me correct login details.
I couldn't figured your problem. I'll point this topic to Fooze. It may take a look for that.
