Objects in "Metaball" doesn't show up in render [SOLVED]
catoskogvoll
Hey!
I've had this problem since yesterday, where I can't use the metaball and get it to show up in either the liveviewer or render. I've attached a screenshot of the file.
What I've tried:
  • Turn on/off "render perfect" on the spheres
  • Turn down the subdivisions on the metaball object
  • Put a octane object tag on the metaball object and the child objects.
  • Turned on check geometries in octane.
Suggestions?
Edit: forgot to post the screenshot. Duh! https://www.dropbox.com/s/mlc6tovm6o6gc ... 7.png?dl=0
i7 2600k - 2x GTX780 SLi - 16GB RAM - 1200W PSU
Gumz
I think you need to make the balls editable.
catoskogvoll
Gumz wrote:I think you need to make the balls editable.
Tried to make the spheres editable, but nothing changes in the render :/
How couldn't get? It's working natively
catoskogvoll
I should probably mention that there's a displacement on the sphere-material as well. Could this cause any problems?
catoskogvoll wrote:I should probably mention that there's a displacement on the sphere-material as well. Could this cause any problems?
No, why don't you try different setups of metaballs?
catoskogvoll
Feel like I've tried everything at this point. You mind checking the project file?
https://www.dropbox.com/s/vs4c7ads69110 ... s.rar?dl=0
enigmasi
Metaball doesn't work if displacement is active as I see from your scene
catoskogvoll
enigmasi wrote:Metaball doesn't work if displacement is active as I see from your scene
From what I understood from aoktar, that shouldn't be a problem :/
tomabobu
That is not the problem. The metaball doesn't has UVs so trying to use a material with "UVW Mapping" as projection won't work.
Using displacement on an object without UVs with "UVW Mapping" will result in the object not showing.
Try other method that works for your surface (spherical, cylindrical, planar...)
Cinema4D R17 / Windows 7 on Intel i7-3930K / 32 GB Ram / GTX 670 / GTX 780 / 3 x GTX 970 on Amfeltech expansion cluster
