Render failure error in Live Viewer.
Gumz
I need a helping hand. When I make any adjustment to materials while Live Viewer is running, I get this error message:
"Render failure! Please check Octane Render log window from -> Settings -> Other"
When I do that it says:
"CUDA error 700 on device 0: Error code unknown.
-> failed to unload module"
And in the log it also says:
"Failed to free page-locked memory"
It's a driver issue? I have updated it not long ago. The driver version is 347.25
Gumz
Never mind. I'm an idiot. Updating driver to 347.52 fixed it.
Gumz
No. It isn't fixed. The problem seem to start when I use images in materials.
I'm using 2.21.1 by the way.
Gumz
I've been pulling my remaining hair out of my head all day, but I think I found the problem.
When I turn of Out Of Core Textures the problem goes away.
cocobrain
Hello
I've encountered "CUDA ERROR 700 on device 0" several times.. + "could not deallocate memory info"
I have turned on "OUT OF CORE" settings, but it crashed Octane & C4D
ANd I also have this : "Tried to access Null item" do you know what it means ?
Thx in advance
cocobrain
XP64/Xeon8c/64Ram
cocobrain wrote:Hello
Thx in advance
cocobrain
XP64/Xeon8c/64Ram
it's a little warning message. Means that plugin try to connect unavailable mesh slots, but not critical. That's not a reason for your problems.
Cuda errors, that's not a bug. We can't catch it before sending data to CUDA. It means that somethings are not fitting to gpu's vram or limits. You should hide/delete some objects or materials to find which causes this.
cocobrain
OK thx for info
I have to admit the amount of objects in my scene has gone out of hands !
I'll search for what is power consuming
take care
cocobrain
