I have a problem
my system is not detecting mY gpus
iray say they are busy or unavailable
in devices list somethimes gpus dont appear
sometimes it works
i try changing octane version & nvidia drivers version
it happents in max 2014, 2014
octane 1.55, or 2.17 fail in the same way
iray fail
quicksilver works well
octane standalone works well
thanks
2X XEON 2680V3 , TITAN Z & 2X GTX580 3GB
octane plugin no gpu devices detect
It looks like this is a fundamental driver/hardware/bios issue rather than with octane itself (considering iRay is also having problems).
I would recommend removing all but one card and doing a clean driver install (you can do this by selecting custom install during the driver install and there should be a clean install tickbox). Trying each card by itself will let you know if it's a particular card that has problems, or the combination of them, or all of them (therefore most likely they are ok and it's something else).
Do you have any other plugins installed in 3ds max that might be using the GPU's before iRay or octane can get their hands on them?
Thanks a lot
I dont Have any cuda plugin
clean driver installation doesnt work
using only titan z fails too
different nvidia driver versions or octane versions fail too
it happens in 3dsmax 2013, 14, 15 standalone works fine
:S
Win 7 64 | Geforce TitanZ & 580 | 2X Xeon2680V3 | 64GB ddr4
:S
I have a same problem with GTX580 and Titan Z too. Do you have resolve this problem?
Dual Xeon E5520 2.27 GHz, 48 GB DDR III
3ds Max 2016x64, Octane render for MAX, Titan Z
