Deformer update problem
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
clement
Hi Ahmet ,
I've a problem trying to render a candle flame made by a mesh deformed by a Wind deformer (here a quick screen vid )
when I try to render the current frame only , it works . But when I switch to a manual range for the rendering , in all the images the deformer seems inactive ( flame is "straight" up )
Did I missed something maybe ? I don't understand why it works for individual frame and not for range ones ?
Octane and Wind Deformer Update problem.mov
(7.88 MiB) Downloaded 3575 times
Win7 x64 / Cinema4D R15.064 / I7 4930K - Nvidia gtx770
Sorry but, do you have any idea about render settings? I can't see what you set in settings?
1-If you select "resend all data" no need to use any object tag but this will not support some features.
2-If you select "Resend only updated objects", you should use object tag to specify which objects are animated.
clement
haaa yes ok sorry :) .
it works fine with both an object tag on the deformed mesh it works fine or switch to 'resend all scene data'
i advice to use second method with some object tags. It's much faster on updates on most big scenes, maybe not for your scene
Return to “Bug Reports”
