Hello everybody
I have really a problem with some hard flickering effects on simple animation.
I attached the movie ...
Has anybody good render settings or experience for glas infant of black screen ??
Thanks in advance for your help.
Attached the mp4 ...
Flickering in Animation
- Attachments
- BottleAnimation.mp4
- (3.47 MiB) Downloaded 10562 times
test you scene with diffuse materials. I think that you have problems on objects or scene scale/rayepsilon.
nice
I just fight as well with some flickering.
In my scene its light-flickering mostlty in the Refl-Indirect Pass.
Its not grain or noise, only light flickering with having only one HDRI
in the scene.
I get rid of this quite well with deflickering filter in AE, but would
like to know how to otimize this in Octane.
I have DL with 1000 Samples and all passes are rendering super clean.
Are there some generell tips for settings/values for the "rayepsilon"?
regards
Mike
in the scene.
regards
Mike
can you try with a sphere/torus etc.. substituted for your middle object with same material? I think there is two possibility. Bad object or insuffient sampling for this setup. I'm curious to see how will behave your material on a simple object
- eyeonestudio
- Contact:
Check...
1.Same Two Surface Close or Not
2.Coherent Ratio = 0 (Animation : Must Set Zero)
3.Surface Normal Correct?
4.Enough Sample? (Need Higher Sample for Refraction)
