Flickering in Animation
martinzip
Hello everybody
I have really a problem with some hard flickering effects on simple animation.
I attached the movie ...
Has anybody good render settings or experience for glas infant of black screen ??
Thanks in advance for your help.
Attached the mp4 ...
BottleAnimation.mp4
(3.47 MiB) Downloaded 10547 times
test you scene with diffuse materials. I think that you have problems on objects or scene scale/rayepsilon.
martinzip
Claymode ??
nice
miohn
I just fight as well with some flickering.
In my scene its light-flickering mostlty in the Refl-Indirect Pass.
Its not grain or noise, only light flickering with having only one HDRI
in the scene.
I get rid of this quite well with deflickering filter in AE, but would
like to know how to otimize this in Octane.
I have DL with 1000 Samples and all passes are rendering super clean.
Are there some generell tips for settings/values for the "rayepsilon"?
regards
Mike
martinzip
Hello aoktar
Diffuse rendering seems fine no flickering!?
My passes where not clean at all ...
What is the next step?
martin
can you try with a sphere/torus etc.. substituted for your middle object with same material? I think there is two possibility. Bad object or insuffient sampling for this setup. I'm curious to see how will behave your material on a simple object
martinzip
ok give me 10 minutes
eyeonestudio
Check...
1.Same Two Surface Close or Not
2.Coherent Ratio = 0 (Animation : Must Set Zero)
3.Surface Normal Correct?
4.Enough Sample? (Need Higher Sample for Refraction)
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
martinzip
Hey aoktar
now it seems to be a flickering which should be possible to solve with anti flicker filter in ae ...
next step ?
torus.mp4
(3.52 MiB) Downloaded 10512 times
