OctaneRender® for Maya® 2.21.1 - 6.2 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Switched to 2.21.1 engine.
  • New "Store to OctaneDB" feature in Octane material and texture nodes. You can store to "LocalDB", "LiveDB" or ORBX pressing this button. Experimental at this stage.
  • New "Open OctaneDB import dialog" button in toolshelf. You can load nodes from "LocalDB" or "LiveDB" using standard Octane outliners. Experimental at this stage.
  • Fixed the hair animation bug in "Movable proxies" animation.
  • Minor fixes...
DOWNLOAD
OctaneRender for Maya 2.21.1 - 6.2 (33.8MB autoinstaller file)
OctaneRender for Maya 2.21.1 - 6.2 Demo (30.9MB autoinstaller file)
Yours,
The OctaneRender™ Team.
itsallgoode9
you are my hero!!!!!! I can't wait to start using this new feature!!!!!!
prodviz
Cool, cheers Jim.
prodviz
Maya is crashing when using the new shelf button and then importing.
p3taoctane
Where is the location of the localDb that the materials are stored on the windows 7 PC
(Found the mac location... could not find the Windows ;)
What is equally unusual is searching for them.
I searched for locaDb, files written today, and the name of the material I saved and it did not show on the Windows or the Mac Search. Are they hidden in some way so that they do not show up with a traditional search?
thanks
prodviz wrote:Maya is crashing when using the new shelf button and then importing.
Works OK for me. How to reproduce?
p3taoctane
Jimstar
where is the local db kept on the win version?
p3taoctane wrote:Jimstar
c:\Users\<user name>\AppData\Roaming\OctaneRender\localDb
prodviz
Just checked.
Maya crashes when I click on 'import' from one of the db shaders.
What nodes exactly you are trying to import when it crashes?
Return to “Autodesk Maya”
