houdini-point-postion-dynamics and octane
useruser
hi everyone,
playing around with houdinis new position-based-dynamics. rendered with octane-plugin/c4d.
btw:
geometry-transfer via alembic works perfect so far but i cant get render a proper motionblur when the vertex-count is changing over time (like ridigbody-dynamic-fracturing, flipfluidmeshes)same with motionblur in post. is there any hack or workaround to render alembic-stuff like that with motionblur in octane?
thanks in advance for any tip/solution.
cheers
Oli
https://vimeo.com/118337246
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
Seekerfinder
That is awesome!
juanjgon
Amazing work!!!
Soon you are going to be able to render this kind of projects with Octane inside Houdini with it's Octane plugin ;)
Fantastic! Octane needs a constant number of vertices in order to do motion blur. I think that if the number of vertices is changing, even the "Motion Vector" pass will not render.
useruser
thanks! :)
juanjgon@ i have Indie only so external renderenginfes are not supoorted atm but i am really looking forward to see the amazing combo houdini/octane in action :)
face-off@ i found a pretty cool workaround posted by mazab@aixsponza. they had the same issue with motionblur in vray/c4d and houdini-flipfluid-alembic-file.
http://forums.cgsociety.org/showpost.ph ... stcount=10
maybe this "alembic-hack" works with octane too.
acc24ex
sick :)
.. tryed getting into houdini a bit, because of stuff like this
Return to “Works In Progress”
