How to utilize motion blur on a RealFlow Particle mesh?
cgmograph
Hi all - tried searching the forums here but didn't find any relevant information.
My dilemma - I have a scene file of a coffee cup mesh (.SD animation file) being fractured by a bullet (made in C4D) as well as a liquid particle mesh (.bin sequence) out of RealFlow 2014. When I add the Octane Tag and turn on motion blur to the objects in my scene, the cup mesh and bullet display motion blur properly but I can't seem to get the liquids to render motion blur, even if I turn up the Particle Mesh objects frame sample rate and/or Octane's motion blur settings. See screenshot below. Any insight would be helpful.
Thanks!
everyday work + blog: http://www.neondopemachine.com
2x Deca-Core Xeon E5-2660 v2 @ 2.2Ghz | 128GB RAM | Windows 7 Ultimate 64bit | 3x GTX 1080 + 3x GTX 780 6GB + 1x Titan Black 6 GB | Cinema4D r17
octane can't supports motion blur for nonconstant vertex amounts. you can try but will give wrong mblur.
prodviz
I'm sure it's not ideal, but reelsmart motion blur might be able to get you out of a hole here.
cgmograph
Ah! Well that explains that! Thanks.
Also, I appreciate the recommendation for RSMB, I've used it extensively in the past but it's usually pretty hideous when applied to liquids. May give it a whirl nonetheless.
a alternative is sub-frame mblur. it was using on times of lacking real motion blur. Do some search on forum if you like it.
garytyler
Tell me if I'm wrong but I think this means you cannot get motion blur for any liquid meshes. I am considering purchasing x-particles or DPIT Effex but it sounds like motion blur will not be possible from the meshes they create either. Is that correct?
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
garytyler wrote:Tell me if I'm wrong but I think this means you cannot get motion blur for any liquid meshes. I am considering purchasing x-particles or DPIT Effex but it sounds like motion blur will not be possible from the meshes they create either. Is that correct?
you may know that i don't write this parts. And as i know that's the limitation. Meshes should have the constant vertex count. Because it cannot follow correct vertexs frame-by-frame to produce correct motion blur.
garytyler
Of course! The standalone can't do it either. I know it's around the top of the features request poll so hopefully one day soon this will be possible at least through X-particles.
coilbook
how come Vray can do motion blur with phoenix FD
