Do Stage Objects work with Octane?
cgmograph
Or am I just doing it wrong?
Example situation - I have a project file with several animated cameras and a Stage Object keyframed from camera to camera so that I don't have to setup several different render sequences. However, my renders only seem to reflect the positioning of the first camera which would suggest that Octane isn't respecting the Stage Objects parameters.
I did a search on the forum but didn't find much information other than someone talking about Stage Objects crashing the program. Can anyone shed some light here?
everyday work + blog: http://www.neondopemachine.com
2x Deca-Core Xeon E5-2660 v2 @ 2.2Ghz | 128GB RAM | Windows 7 Ultimate 64bit | 3x GTX 1080 + 3x GTX 780 6GB + 1x Titan Black 6 GB | Cinema4D r17
it should work.what's your version? can you give me a sample scene?
martincarlson
It works very well for me. I have the same approach rendering different camera views.
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
cgmograph
Slightly delayed response -- apologies but this was totally user error (as it usually is...) -- thanks for your responses nonetheless.
jeffness
Even if this is a really old topic: I will write this down, maybe it helps solving the issue for anyone else:
So i was rendering some frames of a quite heavy scene using the stage object, in which the stage Object defines the camera used for each frame. The first frame always came out fine, whereas from there on the following frames didn't finish. Everything rendered fine until the defined samples were reached, but finishing and saving the passes wont work. As soon as i deactivated the Stage object everything went fine.
Maybe someone else is stumbling over the same issue.
