Octane Labels "ala Keyshot"
RetailSolutions
Hi all,
I have been using Keyshot until now, but made an upgrade to Octane.
It is great and in terms of speed they are not comparable, but there is one feature that I miss very much from Keyshot... and that is Labels... I havent found a way to simply place an image onto the objects surface.
In Keyshot you simply select an image file and position it on the object...
What would be the easiest way to do similar thing in Octane?
Thank you all in advance
Novice Octane user ;)
whersmy
+1
labels have to be "modelled" as objects, can be time-consuming.
Octane does have uwv-mapping
@ op what cpu are you using with Keyshot, and what gpu are you using with octane?
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
RetailSolutions
whersmy wrote:+1
Yeah... thought so... but can be pain in the a$$ when I have a lot of small labels and when I am not sure of their position until I see it.
But I think that it would be great to have the Label feature in Octane as well.
- I render on two PCs, both have GTX 770, but one has i7 970 (hexa) and the other one i5 3570 (Quad).
DylanSaunders
I think Keyshot is the only renderer to have the labels option. While it's a bit fiddly to use, it is very useful.
manalokos
You can use mix material to do this.
itsallgoode9
manalokos wrote:You can use mix material to do this.
yep, that's how I do it, and i do ALOT of bottles. If this is different than how the "labels" function in keyshot works, i'm interested to see how keyshot does it. i've heard other people specifically mention a "labels" functionality from other programs, so i'm wondering if it's something that's done differently.
sethRichardson
You do know labels is literally just a planar projection aligned to the surface normal. Very simple to setup in your host app.
DylanSaunders
With Keyshot 6, it is possible to blend labels with the material of the main object.
voon
Is this like some sort of pseudotexturing with a basic standard diffuse, just using your image?
