OctaneRender® for Maya® 2.20 - 6.1 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Switched to 2.20 engine.
  • Added Octane render layers. You can set the layer ID in the shape's Octane properties and enable layers in Octane general properties.
  • Added Octane Noise texture.
  • Added "Affect alpha" attribute to specular material.
  • Added new passes: "Shadows", "Black shadows", "Colored shadows", "Layer reflections", "Render layer ID", "Render layer mask".
  • Removed "Start samples" attribute from passes settings.
  • Removed "Keep environment" attribute from kernels.
  • Fixed "Coherent ratio" attribute bug.
  • Fixed "Polygon side" texture bug.
  • Minor fixes...
Installation:
DOWNLOAD
OctaneRender for Maya - v6.1 Linux (18.3MB autoinstaller file)
Yours,
The OctaneRender™ Team.
Next version HERE.
Return to “Autodesk Maya”
