Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on Linux operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses, just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
Just like OctaneRender™ Standalone, the Maya® plugin product also needs an additional OctaneLive license and be activated on a machine.
This has to be done in the plugin interface panel in Maya, and is covered in the included PDF manual.
It can only be done after an OctaneRender™ Standalone license is already activated on the machine in question.
CHANGES AND FIXES SINCE LAST RELEASE:
- Switched to 2.20 engine.
- Added Octane render layers. You can set the layer ID in the shape's Octane properties and enable layers in Octane general properties.
- Added Octane Noise texture.
- Added "Affect alpha" attribute to specular material.
- Added new passes: "Shadows", "Black shadows", "Colored shadows", "Layer reflections", "Render layer ID", "Render layer mask".
- Removed "Start samples" attribute from passes settings.
- Removed "Keep environment" attribute from kernels.
- Fixed "Coherent ratio" attribute bug.
- Fixed "Polygon side" texture bug.
- Minor fixes...
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - v6.1 Linux (18.3MB autoinstaller file)
Yours,
The OctaneRender™ Team.
