OctaneRender® for Maya® 2.20 - 6.1 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Switched to 2.20 engine.
  • Added Octane render layers. You can set the layer ID in the shape's Octane properties and enable layers in Octane general properties.
  • Added Octane Noise texture.
  • Added "Affect alpha" attribute to specular material.
  • Added new passes: "Shadows", "Black shadows", "Colored shadows", "Layer reflections", "Render layer ID", "Render layer mask".
  • Removed "Start samples" attribute from passes settings.
  • Removed "Keep environment" attribute from kernels.
  • Fixed "Coherent ratio" attribute bug.
  • Fixed "Polygon side" texture bug.
  • Minor fixes...
DOWNLOAD
OctaneRender for Maya 2.20 - 6.1 (33.9MB autoinstaller file)
OctaneRender for Maya 2.20 - 6.1 Demo (31.9MB autoinstaller file)
Yours,
The OctaneRender™ Team.
AhmadR
Thanks Jim,
solomon
Thanks. a quick question JimStar ~ support for double sided materials in Octane, will this be supported soon? is there a work around?
Solomon W. Jagwe
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
prodviz
Awesome, cheers Jim.
I think the double sided material is in there as the 'Polygon Side'.
prodviz
Hi Jim,
just before I install this update, does the network rendering work ok?
'Re: Network render issue
Postby abstrax » Sat Nov 15, 2014 9:08 pm
I think both the latest 3ds max and the Maya plugins use SDK of version 2.11.1, which means you have to install Standalone 2.11.1, which you can get from here: viewtopic.php?f=33&t=42854'
cheers.
p3taoctane
Suggestion for default settings in Octane Render Settings.
Have Tone mapped HDR
Enable Live DB Refresh
Verbose mode
Change Names to Unique
ALL Selected by default...
Personally I like Swatch Quality to zero by default as well but I realize that may be not popular. 8-)
Maya User thoughts?
zurakan
Hi Jimstar
I try to use Octane Layer ID
info channel type Object layer ID ===== it not working
Render passes , Object id , Previre pass > Object id ==== it not working
when enable Render layer is On
octane Diffuse shader use matte option
In alpha channel ,render layer it cut off the Shadows in alpha
I hope you can explain how to use OBJ layer id .
Thank so much :)
ps. twoside material awesome
Win7 Ultimate x64 xeon Core 40 / maya2Octane 1.20a , maya 2014SP4 & Octane 1.50,
128GB Ram, 4 x GTX Titan 6GB
solomon
for the OctaneSky, when I choose the Texture Environment as the Type, and add an image, the IPR fails to recognise it, but if I switch back to Daylight Environment ~ the IPR works.. so I think the Texture Environment has a bug
Solomon W. Jagwe
Thank you guys for reports. I will check it.
p3taoctane
I know you can import a material from the live data base. How about one from a saved local file?
Anyway to do this into Maya
Peter
Return to “Autodesk Maya”
