C4d Crashing on Long Renders
lextrickett
Hi, i'm running into an issue on long renders.
I'm using R15, latest plugin, latest Cuda update.
I've attached a crash report.
Thanks very much,
Lex
BUG REPORT.zip
(39.73 KiB) Downloaded 119 times
be sure that you have enough free vram while rendering. are you?
lextrickett
Hi Aoktar,
I'm running a gtx 680 with 2gb RAM. Excuse my ignorance but how would I change the VRAM allocation? My scene is quite texture heavy.
I think my Wifi might be causing the crash as its a bit inconsistent. at times it might drop connection? and i don't think octane likes it when you are not online.
Lex
TonyBoy
Hi Lex,
You have no control over how much vram is used except controlling the size of your texture maps and connecting objects or reducing the number of polygons in each object. The texture size is the easiest (how big is the object in the scene, how far from the camera?). Unanimated things can be gathered together as one object Using the connect command.
Tony
