i tried to install the Cinema 4D (R15) octane demo version on a mac pro with a gtx 970. But it won't work, because it shows an error message which says "There is no CUDA device which is selected..." When i try to check the GPU in the octane options, the same message appears, and when i close the settings tab, the 970 gtx automatically gets unchecked. BUT cuda works fine, in every other software (for example the octane standalone demo), and also inside cinema 4d (turbulence fd). Any chance for me to get this working?
Thanks!
OSX 10.10.1
Cinema 4D R15
GTX 970
NVIDIA Driver 343.01.02f03 (tried older and newer versions, problem is still there)
CUDA 6.5.25 (with newer and older versions cuda doesn't work)
C4D - 970GTX - no CUDA device selected
can you check in standalone demo? Also could you please post a sshot to see this messsage?
http://render.otoy.com/downloads.php
the standalone demo is working fine, and the gtx 970 is checked. i can load the demo scenes and everything works perfect and octane renders immediately.
here is the message in c4d:
http://i.imgur.com/UoTUasU.png
the gpu isn't checked, and i can't change it. when closing the settings, the gpu is unchecked again...
2.16 is loaded today in early. Nice to hear, keep enjoyEric3D wrote:Just downloaded the 2.16 demo, now it works! Did you updated it today? I downloaded a version on monday, and maybe it was an older version? now everything works, thanks!
- sirkaoselite
Maybe i have a similar problem?
''Started logging on 07.01.15 10:44:08
OctaneRender version 2.16 (2160000)
Tried to access attribute via invalid ID A_ALLOW_STATISTICS_COLLECTION (10)
FileName::toJuceFile() can be called only on absolute file names
--------------------------- EXPORT LOG ---------------------------
Export materials time= 0.068 ms
Collect objects time= 0.019 ms
Meshes creation time = 1.755 ms
Octane voxelization time = 0.003 ms
Sending to Octane engine time = 0.243 ms
Total export Time = 244.843 ms
CUDA error 719 on device 0: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> failed to copy 2D array to device
-> failed to deallocate device array
-> could not get memory info
-> failed to copy memory to device.
device 0: failed to upload data texture 10 of context 0
-> failed to deallocate device memory
CUDA error 719 on device 1: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> failed to unload module
Can't Read Preset File: C:\Program Files\MAXON\CINEMA 4D R16\plugins\c4doctanepresets.dat
You probably haven't installed a recent NVIDIA driver (>= 344).sirkaoselite wrote:Maybe i have a similar problem?
- sirkaoselite
I have the 347 driver and also my problem is in this post: http://render.otoy.com/forum/viewtopic.php?f=25&t=44254abstrax wrote:You probably haven't installed a recent NVIDIA driver (>= 344).sirkaoselite wrote:Maybe i have a similar problem?
i have writed my last reply but is in waiting of approval
True, I didn't read carefully enough. Your problem is not driver related. I will reply in the other thread.sirkaoselite wrote:I have the 347 driver and also my problem is in this post: http://render.otoy.com/forum/viewtopic.php?f=25&t=44254abstrax wrote:You probably haven't installed a recent NVIDIA driver (>= 344).sirkaoselite wrote:Maybe i have a similar problem?
