Network render - animation error
gazukull
Hi!
I will try to explain this as best as possible.
When running an animation sequence, whilst using network render, when the error window pops up talking about lost samples (usually like 1-2 samples), the camera stops updating its position until you press ok on the error dialog. So if not paying attention to the render sequence, it gets all out of wack (Camera essentially stops moving).
I have temporarily stopped using network render on animations because of this.
I think if there was a way to suppress the dialog for lost samples, the error would not occur.
Thank you for your time!
System info:
Windows 8.1 x64
16 GB RAM
5 x 780 GTX 3GB
Geforce 344.11
Poser Game Dev 10.0.5.28164 (sr5)
Octane Plug 2.13.0.36
Win 8.1 X64 / 6x780GTX / AMD FX-8320 / 32GB RAM
abstrax
gazukull wrote:Hi!
System info:
Windows 8.1 x64
16 GB RAM
5 x 780 GTX 3GB
Geforce 344.11
Try to use version 2.16: http://render.otoy.com/forum/viewtopic.php?f=45&t=42585
We fixed quite a few net render bugs and hopefully your problem is solved, too.
You will need to use the same release of Standalone for the slave as the plugin - so if using the 2.16 slave, also use the latest TEST release of the Poser plugin (2.16.0.38).
gazukull
I think I missed the bus. I cannot seem to find an Octane Standalone 2.16 in the Development Build Releases subforum.
I guess I should wait a bit until it returns?
EDIT - I see I can jump into 2.15 now, I will see how that goes.
wimvdb
gazukull wrote:I think I missed the bus. I cannot seem to find an Octane Standalone 2.16 in the Development Build Releases subforum.
2.16 is at another location - http://render.otoy.com/forum/viewforum.php?f=24
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
gazukull
Thanks a ton!!! -G
EDIT: 2.16 seems to have fixed the issue! Excellent thank you.
Return to “Poser”
