Scripting node issue with the environment node.
Forum for OctaneRender Lua scripting examples, discussion and support.
grimm
When you hook a script node that passes on an texture image to the environment texture node the importance sampling does not work. I'm not sure if it's something I'm not doing correctly or if it's a bug?
anim_texture.lua
(2.56 KiB) Downloaded 334 times
Jason
roeland
It's a bug in the CDF calculation, it breaks if the texture is inside another node graph. We'll fix this in the next version.
Roeland
grimm
Excellent, thanks Roeland. :)
Return to “Lua Scripting”
