Displacement not working
tane
Hey everybody,
it seems as if the displacement is not working anymore on my workstation.
I have no clue why.
I opened a new scene and set renderer to Octane.
In the material editor I create a new simple white diffuse material.
I set a displacement node with a greyscale Map in it. But it does not show me any displacement. I set the value from 0.01 to 5.0 without any changes.
Any hints, what I might be doing wrong? I used it last time some months ago and it was working back then.
I am using Max 2015 with the newest Max-plugin.
Thank you all in advance
Karba
Do you use image texture for the displacement?
tane
I tried both, RGB Image node and Greyscale Image node. Also Noise Texture.
All of it is not working.
wastzzz
Did you apply a mapping? Like UVWMap.
M.
tane
Yes, mapping is applied - the diffuse texture looks good with the same UVs.
I remember that it worked before and I could see the displacement on the small material preview spheres. Now it isn't visible there either.
I tried values from 0.001 to 1000.0 without any visual effect.
brettg19802
I agree, the displacement nodes aren't working anymore with the new version. Can't get noise or turbulence working right anymore. It used to work, but now its broken.
coilbook
i could never get displacement to work using octane noise or any other octane maps I thought it is only for bitmaps
tane
but even those don't work for me.
tane
It is still not working here :-(
Any new information about it?
akira
Hi
It works here, i made a simple sample for you to test. Let's see if it work or not on your pc.
displacement.zip
(357.43 KiB) Downloaded 225 times
Return to “Autodesk 3Ds Max”
