IMPORTED MESH BLACK RENDER
danielsiegl
Hello there!
I have a problem with some converted .STEP files and wanted to know if someone else had similar problems.
It looks like that something went wrong with the Poly Mesh.
The Mesh is not that complex (86,082 Tris) Normals seem to be ok!
Rendering with Maya Software is no Problem and it looks as expected.
The Hardware is 2x GTX 780 3GB
Any Ideas?
Thank you so much!
Daniel
Snoopy
Hello, did you check the orientation of the normals?
Regards,
Snoopy
Snoopy
Make sure you don't have duplicated polys on top of each other.
Snoopy
danielsiegl
Thank you so much guys!
It looks like it is the duplicated polys problem. But i have no Idea how to get this fixed.
Anyways, I fixed it in camera settings (?)
Near Clip Plane to 1.000 and it worked. Strange.
Thank you!
Daniel
itsallgoode9
if it's lamina faces: mesh ->cleanup then deselect all boxes except lamina faces.
if it's just two meshes that have been combined but the verts haven't been welded: mesh->separate then delete one of the meshes.
Return to “Autodesk Maya”
