OctaneRender® for Maya® 2.11.1 - 5.5 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Fixed SP5 Viewport 2.0 issue with Octane Sun and Octane Light.
  • Fixed broken ability to interrupt the interactive render by ESC.
  • Fixed displaying of Octane shaders in Viewport 2.0.
  • Fixed Octane texture mapping in UVeditor in case the transform is applied to it.
  • Linux version is moved to Maya 2015.
DOWNLOAD
OctaneRender for Maya 2.11 - 5.5 (31.8MB autoinstaller file)
OctaneRender for Maya 2.11 - 5.5 Demo (30.0MB autoinstaller file)
Yours,
The OctaneRender™ Team.
AhmadR
Thanks Alot Jim,...
ypolyz
Thanks JimStar.
wzxOctane
Thanks JimStar.
prodviz
Cheers Jim.
Hope the Imager Gamma, curve and highlight compression is fixed.
cheers.
abstractmedia
Thanks!
prodviz wrote:Cheers Jim.
cheers.
There is nothing to fix as It's not a bug.
Be sure that you are tuning the same camera as is chosen for rendering inside current IPR session.
prodviz
Here's a download to a scene file which shows the issue.
The Imager's vignette, exposure etc. work fine, but the highlight compression and curve do not respond:
http://render.otoy.com/forum/viewtopic.php?f=28&t=43284
edit: this is with the previous plugin. Will check the latest version.
prodviz
EDIT:
OK, I've rechecked it. As I said - there is no bug here.
If you set the HDR image into live preview - don't forget that it has linear tonemapping by default. In your case - either do the preview in non-hdr mode, or enable "Tonamapped HDR" in Octane global settings.
Next version HERE.
Return to “Autodesk Maya”
